kronoSX
- Feb 28, 2005
I dont know what to do now but here is my fault.
1-I flashed a rom kikat to instruction given here,All went well untill the reboot where the samsung logo appears
2-The logo stayed on for 20 minutes and nothing,My battery was 50% at the time.
3-I then loaded my back up from clockwork recovery,rebooted tablet and i was back on 4.1 andriod.
3- i kept getting the status 7 error during the the update for the zip.
4-I proceeded to change the file to .doc to take out those first lines,which identifies the product model(i can remember what that was but i fixed it)
5-Now i was getting the status 6 error,i then proceeded to fix this via notepad++.(something about changing to hex for unix code)I fixed that
5-while all this the battery was now at 20%.
6-I tried flashing the rom again and this time it worked as all the fixes were in place,as per instruction from the forum.
7- the tablet booted up but still the samsung logo was on,Ok i left it as the first boot takes long,The battery was at 15% at that time.
8-I completely forgot about the tablet,as i was busy fixing a ps3 and psp with cfw.
9-I remembered gawd damnit.
10-Ran to the tablet and saw the tablet off(i then proceeded to put it in recovery mode but alas,all that came up was a battery sign with a loading gif.
11-Now the tablet is dead and it never really booted.I plugged in the usb and instead of charging it shows the battery sign with a loading circle,its as if the software did not complete for the battery monitoring and usb charging.
12-Is there not a way to charge the battery without going via the OS andriod.Is there not a special charging cable that just charge the battery.
13-My tablet is rooted and is modified in every way.
My solution
Can this work,I take the back cover off and take the battery out,Fine the + and - and connect a 5v charger to these point.....charging it just enough for a recovery process.If there is someone that know of any other way or the battery pin layouts for charging.
Taking it to a repair centre is not an option,even if it still under warranty.
I need to fix via incognito .I am good in what i do ,but individual members are good in what they do and far better clued up with these problems.Let me know what you guys and gals come up with...........thank you for reading my plight
My solution
