TonyA
- Oct 13, 2005
Hi some help and advise please.
My son has a relatively old Pc thats been upgraded over time.
It started life with a Gigabyte GST 800, 2.4 P4 etc
It has been upgraded to
2 * 250 HDD
2 * DVD RW
1 * Stiffy
GF Force 6600Gt
1024 Mb Ram DDR 266
Last when the boy logged off and shut after playing Morrow wind all was fine.
When he rebooted it displayed and error loading Win Xp Pro Service pack 2 " some driver (NTFS Kernel) was corrupt. After some fiddling with Win XP disc I managed to get it to boot and then found that it gave an error that said unable to load resources (from Windows). I checked PC properties and found it only registered 256 Mb ram. Closed down machine and opened up.
Reaseated all the Ram. In doing so Had to remove graphics card (6600GT). replaced all and checked connections , all fine. Rebooted and found no graphics to monitor. Checked again and still had same problem PC appears to boot Lights come on, network connection light on Router goes on, DVD lights flash and then go off. Red Light indicating HDD access stays on (or perhaps its Bios indicating fault). Monitor does not come on, power light flashes but does not receive graphics. I Think I damaged either
RAM
Graphics Card
or Mother Board
Any one got any advice. To replace PC may cost a lot as HDD are IDE, Graphics card is AGP etc. I understand most new mother boards are SATA, PCI express etc. If I replace can I still keep the HDD and DVD.
Ie Buy new mother board, new graphics card and new RAm (2GB FSB 800)
Thanks in advance
2 * 250 HDD
2 * DVD RW
1 * Stiffy
GF Force 6600Gt
1024 Mb Ram DDR 266
RAM
Graphics Card
or Mother Board
Thanks in advance
