Help with hardware selection
wesleyfraser
Good day people,
I would just like to know it the following components will go together?
This case : http://www.sybaritic.co.za/store/product_info.php?cPath=50_52&products_id=6063
This motherboard : http://www.sybaritic.co.za/store/product_info.php?products_id=7837
This gfx card : http://www.sybaritic.co.za/store/product_info.php?cPath=74_75&products_id=7263
The reason i'm asking is I bought the gfx card the other day and when I tried it, it was to high for another case that i had not the above mentioned case, so would like to know if the micro atx mother board is the correct board for the case and if the gfx card would fit in the case?
Thanks in advance
The Big Firefly
wesleyfraser said:
Good day people,
The reason i'm asking is I bought the gfx card the other day and when I tried it, it was to high for the case, so would like to know if the micro atx mother board is the correct board for the case and if the gfx card would fit in the case?
Thanks in advance
i dont get it. you say it dont fit then you ask if is gonna fit....:confused:
wesleyfraser
Sorry about that fixed my previous post, my old case was not high enough but i only found that out after i bought the case.
killadoob
dude why do you want to spend so much a on case geez
save 700 and get a better cpu or m/b or more memory or a better vga card
seriously 1200 for a case is a complete waste of money
wesleyfraser
what case would you recommend then that would look good as a HTPC and comes with a power supply?
killadoob
well i would say a gaming bomb but if you looking for a flat case then that would be ok
chenbro gaming bomb(300w power supply)
i run a 3200+
6600gt
same board as above
2 optical drive
runs all that fine
this is an office pc or gaming pc?
wesleyfraser
Its for a home theatre pc so i don't need the highest specs i already have the gfx card mentioned above. So i'm looking for a case that is something similiar to the above mentioned case...
killadoob
yea seriously dude 1200 for a case that is going to house a 5200fx is just really madness
rather give me the money i will go get drunk and piss it out just for you :)
