The cost has reduced to almost nothing in the past two years, the whole cost per meter amortised is a thing of the past, almost all residential areas have fibre installed for free, even if not in useNo. If you want a low usage solution go wireless. The civil works for fibre is expensive and needs to be amortized over a reasonable period.
The cost of fibre is determined mostly by the civil works required, and civil works cost is based on meters per subscriber. The reason why Vumatel can have cheaper services through Vuma Reach is because they can spend a lot less money per customer on the civil works - mostly because the population density in those areas are higher. And they deploy fibre in the air and multiplex like crazy.
The actual bandwidth of fibre is almost as cheap as chips. The higher tier packages have a higher profit margin than the lower tier ones.
What are you smoking? The cost is still a major major component!The cost has reduced to almost nothing in the past two years, the whole cost per meter amortised is a thing of the past, almost all residential areas have fibre installed for free, even if not in use
The only cost is the router which they literally borrow to you
We are in agreement then, the actual cost of bandwidth is cheap as chips
If the hardware costs are not relevant anymore, why are the pricing models so high and based solely on speed
When do they have cheaper capped products
Have I seen correctly in the past that these FNO's only have approx 30 to 40 or 50 % of their fibre installs active ?What are you smoking? The cost is still a major major component!
The figures for most sururbs are roughly as follows:
1) Price per meter = ~R600
2) avg House front in meters = ~ 30m
3) Connection rate = ~ 33%
4) Cost of civil works per paying connection = 600*30*(1/0.33) = ~ R54 000
5) Assuming their debt is cheap at 7% interest rate
6) Amortizing civil works over 7 years = ~ R840 per month.
So their cost of installation did come down. But only later. And even if their cost is half now - that is still a big chunk of change.
You can have a look at the debt load of these companies. They have a massive amount of debt that need to be repaid.
If the FNO's are still keeping the cheapest speeds relatively expensive (like I feel they are, as I won't pull the trigger yet), then another aspect to consider is they don't want greater percentages even signing up & activating as it's a strain on their networks they're having problems coping with already ?
Thanks, my main point about it all is I get the impression, generally, that FNO's don't want too many customers - a ridiculous notion, I'll admit.Not sure there's any network strain issues on Vumatel's side. When they went live in my area in 2018 the entry level package was 4/1. In January 2019 it changed to 10/2. In March 2021 this changed to 10/10, with a slight price increase. On 1 July 2021 10/10 was dropped and 20/10 became the entry level, including a price cut. In June 2022 they announced a limited time speed doubling promo which would last until the end of August. 2 weeks later the end date was extended to 31 January 2023. In October they announced that the speed changes would be made permanent. So today the entry level Vuma package is 50/50, up from 4/1 about 5 years ago, and at pretty much the same price.
Vumatel is currently one of the most expensive options and you can get 50/50 for under R500pm. Not sure how much more you expect the price to drop, but I think your expectations need an adjustment more than the prices do.Thanks, my main point about it all is I get the impression, generally, that FNO's don't want too many customers - a ridiculous notion, I'll admit.
All or primarily because of the
relatively high entry cost to consumers (IMO, others of you can disagree).
If and when consumers stop signing up, presumably FNO's will be forced into dropping prices even more for base packages.
Maybe they won't even do that - just offer 50 or 100 Mbps for R500 - R600 ?
Apart from Herotel, of course, which is an exception right now & already doing so on 50 Mbps.
Firstly, I don't have Vuma as an option.Vumatel is currently one of the most expensive options and you can get 50/50 for under R500pm. Not sure how much more you expect the price to drop, but I think your expectations need an adjustment more than the prices do.
Ah, my bad..... there are a few listed on Vumatel's Shop page, but I see they are reduced subs for the first 1-3 months, pretty misleading. The lowest "normal" price without any fine print starts at R649. Still not bad IMHO vs the 4/1 service you got 5 years ago at the same price.Firstly, I don't have Vuma as an option.
The article uses their 50/50 through Afrihost at R727, so who offers it at below R500 ?
I'd personally consider a 30 / 3 line (slowest Frogfoot have) at around R350 pm.
No problem - it's all theoretical in my case, anyway, because Vuma's unavailable to me, and for now LTE's a perfect solution ; much better value for money.Ah, my bad..... there are a few listed on Vumatel's Shop page, but I see they are reduced subs for the first 1-3 months, pretty misleading. The lowest "normal" price without any fine print starts at R649. Still not bad IMHO vs the 4/1 service you got 5 years ago at the same price.
Should I care how many unconnected homes have pass over fibre and whether or not lamb's blood was painted on the doors to these homes?Vumatel is the largest residential fibre operator in the country, with 1.6 million homes passed and 450,000 connected.
Openserve, although having passed only 890,000 homes, has a better connection rate than Vumatel and isn’t far behind the leader in terms of homes connected.
Uh? I would really like to understand these "exclusive contracts". I am a trustee in a complex, Vumatel approached us and asked us to install fibre and we agreed on dates, routes through the complex and reinstatement. There was no exclusive contract.Vumatel has made a point of going after compexes and estates and locking the body corporates into exclusive contracts, OpenServe used to do that before Vumatel existed (and likely still tries to).
My understanding is that it comes down to the trunking where the first company to dig within a complex and put in trunking will not allow shared access to that trunking when/if another FNO wants to service the same complex.Uh? I would really like to understand these "exclusive contracts". I am a trustee in a complex, Vumatel approached us and asked us to install fibre and we agreed on dates, routes through the complex and reinstatement. There was no exclusive contract.
OpenServe mapped our complex a year before Vumatel approached us and told us they will install fibre - but that didn't happen. About 6 months after Vumatel installed OpenServe removed us from the area that will be covered in future.
The simple truth is that there isn't these massive "exclusivity contracts". It just doesnt make sense to build in an area where fibre was already deployed because your connectivity rate will suffer. So "first to the post" almost wins by default in an area.
P. S. Exclusivity contracts will also in all likelyhood be illegal. Body Corporates don't like lots of digging (I can tell you stories about why ) so a lot of them won't make it easy for a second entrant even if they don't have an exclusivity contract.
Pretty much. Nobody wants to share their trunking, and while there's nothing stopping others from trenching and laying their own (except maybe body corporates saying no, in the case of complexes), it typically isn't financially viable unless you can somehow guarantee the number of signups you would get.My understanding is that it comes down to the trunking where the first company to dig within a complex and put in trunking will not allow shared access to that trunking when/if another FNO wants to service the same complex.
The end result is complexes that are serviced by only one FNO and there is no scope for any other FNOs to put their own fibre optic into the same trunking.
