Muttley
- Jan 6, 2016
Hi folks,
I'm currently setting up my network in our new home.
I have to place my LTE router upstairs in the spare bedroom as this is where I get the best reception. As a result, I now have to run 2 ethernet cables from the router, 1 to my access point (POE) and the other 1 downstairs to connect my HTPC. The cables need to run along a wall, under a door and then around a door frame- basically from the left side of the image below which shows the access point.
The problem is, is that I'd like to try not have to double up on the ethernet cables and there's no power where the access point is for a switch- plus it may not look great. Getting 1 cable to fit under the door was a mission, doubt a second will fit.
I ran 1 ethernet cable yesterday for the access point (still to need to attach it to the wall)
Please ignore the shoes
Still need to run the second cable as follows:
Does anyone have suggestions?
I wish I could get something like an RJ45 splitter - not sure if this would work...
