Hometheatre system, more subs=overheat?
sitnet
Hey ppl!!! :) Haven't posted for ages... I'm so busy!:rolleyes:
But anyway though, I have a question for all the sound techies out there. I have a Wharfedale 5.1 Surround sound system, and decided to add an extra sub-woofer. OK so it came with only one sub so this is what worries me. I'm afraid that something will blow or overheat over time. The amp does have a fan in though. Oh and BTW the second sub came off an old and cheap diamond home theater. About the same size as the original sub (and same independence, not sure about watt though, doesn't indicate).
Is there a way of telling if I am screwing up my amp?
Thanx:)
ponder
How? The subs have their own power supplies and the amp does nothing but supply the signal in a unamplified form.
sitnet
no, no. The subs dont have their own power. The subs only have one cable each going to the amp/dvd player. Thus the amp provides the actuall amplified signal.
crysis
You could always add your own fan. Do some DIY work. There is a company called yebo electronics that sell small AC fans that can work just fine.
AMG133
but how many sub out's does the amp have? or are you going to split the cable and share the 1 port with the 2 subs?
sitnet
Yes exactly, I'm splitting one cable to 2 subs. Tonight I discovered that there is definitively not a problem for the amp to produce enough power because when I turned up the volume higher than normal the one sub (the cheap Diamond one) totally bottomed out. Like reached it's limit.
That was quite surprising:D
ponder
:eek:
So what is the rating of the subs? You must have one beast of an amp to drive any reasonable sub, 200W+
Dolby
What is the model ?
If it's a home theatre in a box with smallish speakers, you're probably looking at less than 40 watts per channel - thats REAL watts. Even that I doubt :/
Mier
The chances are good that you will stuff up the amp. By splitting the cable and connecting more than 1 sub, you are effectively reducing the load impedance. This will force the amp (and its power supply unit) to deliver more current (ampere) to drive the load. Apart from the excessive heat, which will reduce the life expectancy of the equipment, the amp can also start to clip which can damage the speakers.
