How do I connect a modern Smart TV to a DVD Surround Sound System
TE3TH
I recently purchased a 58" Hisense UHD Smart TV. I currently own an older LG DVD Surround Sound System that does not have an HDMI port, only RCA (Red, White and Yellow)
The TV does not have RCA OUT, only RCA IN.
Would it be possible for me to purchase an HDMI to AV adapter and connect two systems? Would this work?
Surround Sound: LG 5.1 Channel Home Theatre System DH3120S 3140
TV: HISENSE 146 cm (58") Smart UHD TV 58A6100UW
Any advice greatly appreciated!!
Lupus
If you ever found a way you'd not get 5.1 anyway as these 5.1 systems are limited. Maybe look at upgrading your system. Even if it's a basic AVR in a box.
SauRoNZA
You never were going to get surround sound from those RCA’s. Only stereo.
The surround only applies to the source itself (the DVD player).
Will probably cost less to replace the whole lot than get a converter than is useless anyway.
Does the LG possibly have an Optical In? The Hisense likely has an Optical Out.
