How long does it take for afrihost to upgrade your ADSL line speed?
ADrunkTeddyBear
I have moved over to Afrihost for little over 2 weeks and i still havent had my ADSL Line synced to 8MB/s. How long does it usually take for them to upgrade your ADSL Line?
Masataka
Did you move there under a different line speed and then asked to have your speed upgraded?
Upgrades should be done same day. Took just over an hour for my line to start syncing at the new speed after chatting with telkom, and then 1min for crystal web to increase the data side.
Johnatan56
That depends on two factors.
One: does your port need to be changed/does your port support higher speeds.
Two: how long will the OpenServe tech take.
If the port doesn't need to be physically changed it should be quite quick, a couple of hours at most.
