How to connect gate motor to battery system? Hansa Elite H/D
Milie
Johannesburg
Hello,
So some a**hole/s today decided they would like access to my property and cut the lock that connects the motor's arm to the gate but luckily they didn't gain access to the house. I have connected a better locking system but the gate hasn't got a backup system so it has to be manually unlocked/unhinged every time we have loadshedding.
I need some help/advice on connecting a battery system to an existing gate motor.
I have this motor (below) which is connected to a single gate via two bars that swivel (see this) so I assume it's a double swing motor then?
I want to connect it to a new battery system that will be charged through the existing power connection. I have found this site that has the parts, mainly:
HANSA – PCB DOUBLE SWING 24V
HANSA – SPEEDO BATTERY CHARGER COMPLETE PANEL
What else do I need besides the batteries, cable and enclosure?
Or is there another way of doing this? Those prices are quite expensive and the current motor is still working well after 20+ years.
Are these below viable?
Hansa Speedo Battery Charger Complete Panel
Hansa Speedo 24V Alternative Power Supply
I have some experience/knowledge of batteries, wiring, inverters etc. but any and all assistance is appreciated.
Will this work?
Is your current motor 24 volt? I got a nice hansa 24 Volt motor gate, it got a power supply 220 to 24vdc, and 2 alarm batteries.
If your motor is 24 volt, it will be easy, but if 220 volt ac, more money.
Hello,
Best would be to call the guys from the website and ask them if no one here can help you...
Hello,
So you need an external DC source that would supply power to the internal battery?
Will this work?
My only problem with it is that getting a 24V out of a 12V 7Ah battery is not going to work well, it would have been nice if it was just a 24V.
Done this for customers many times
You need
Box (suggest York fibreglass enclosure) big enough to house everything
2 x 12 volt 9 a/h lead-acid batteries (li-ion won't work on account of the high initial current)
A 24 volt battery charger
Wiring to the gate motor controller, preferably in conduit
This charger works - https://www.takealot.com/intelligent-12-24v-battery-charger/PLID72165898
I did speak to a Hansa Gates representative and they said I need to upgrade the system to have backup power which is unfortunate. But I'm going to look into chrisc's suggestion. Thanks.
Yes, I believe so. The motor is powered from the mains but idealy I would like: power -> batteries -> control board -> gate motor.
You need
Thanks for the reply. This is the control board:
It looks like it will support 24V (Sorry for the mess, the board is located in a bad place, a lot of sand/mud etc. will change the location of it too.)
So as simple as wiring 2 x 12v 9a/h in series, connecting the charger to the batteries and then the battery to the control board's main power input?
Can you see my reply above? It looks to be the same?
There is a circuit, two diodes and one resistor which control the charge current, I will post the pic later when I am at a computer.
Hard to tell where the spiders stop and the wiring starts
lmao yeah, the gate is pretty far from the house so all the wiring for the gate, pool and driveway lighting is located in an outdoor 'service room' next to the gate. Doesn't get attention very often so its become a nest.
I cleaned it a bit to see the cabling better. Not sure if that helps.
The circuit is simple to construct. Regulator IC 7812 gives 12 volts regulated DC for powering the circuit as well as to charge the rechargeable battery. LED indicates the power on status. When the mains power is available, diode D1 forward biases and passes current into the battery through R2. Value of R2 is selected to give 90 mA current (12/100 = 0.1A) for slow charging
Watts
Amp / / volts
Please share a better pic of your wiring pin out top left. Depends where your 24V out is, you might need to cut it in somewhere on that pc board.
a clear pic of the wiring read out top left, connection labeling.
Sorry for the late reply, I was away for a couple of weeks. Now to tackle this project. The pictures above show the wiring and the diagram displays labels clearly. Unfortunately, I see that the radio controls are 24v while the gate motor is 220v. I have 2 x 12v batteries and a 24v charger. I assume I would need an inverter to change 24v to 220v?
