How to fix a crack on a plastic bumper (Toyota Corrola)
Lino
I am back
As you all know I am currently using my aunts Toyota as my car is being fixed.
However I noticed a fairly large crack on my aunts Toyotas back bumper. More like its cracked on the side and there is a hole now. How on earth do I fix it before she comes back?
RazedInBlack
RazedInBlack
You knocked your aunt's car! :eek:
Go to a scrap yard and get one there. The just have it replaced.
Pitbull
Verboten
Plastic weld it.
Just remove the bumper, take a soldiering iron and heat the plastic to melt with the other side of the crack. Do it on the inside and it should be fine. Even add a bit of extra plastic if you want to reinforce it a bit.
bwana
MyBroadband
Super Moderator
You sure you did it? I once went on a mission fixing a dent in my grandfathers car only to have him tell me later my gran had dinged the car. :eek:
