pinball wizard
- Feb 9, 2010
Ya, but add an extra R260 unless you go to Hendrina to pick it up...
jissus are door that expensive now?Ya, but add an extra R260 unless you go to Hendrina to pick it up...
Builders will fix the door..?Take the door off, take it to builders and let them sort it out for you.
Option two - leave the door as is and when anybody gives you **** just point to the door and give them a sly smile.
Agree with fill with solid material but, not newspaper..Okay. You can plug up the hole with about a kilo of Polyfiller, which will cause a slump.
What you should do is add some solid material, like an extra piece of ply wood or maybe stuff the hole with newspaper then apply Polyfiller.
They will sell you a new one and cut it to size and make sure the hinges are in the correct place.Builders will fix the door..?
Tripped over my dog and went head first into the door.
Honestly surprised it wasn't a bigger hole.
What's the best way to fix this?
More likely what happened.I need to do the same thing, except mine wasn't an accident; I put my fist through my door![]()
That is good to know..They will sell you a new one and cut it to size and make sure the hinges are in the correct place.
Who was on the other side?I need to do the same thing, except mine wasn't an accident; I put my fist through my door![]()
https://www.amazon.com/Quick-Wood-471050-24-QuikWood-Putty/dp/B000VPO0R8
You will find it at Brights or Builders or well most hardware stores
Honestly I wouldnt take most of the advice from above other than replacing the door.
