how to get the 3g and lan connection to work at same time in Ubuntu 10.10?
poorestguy
Hi guys,
I'm having trouble trying to get my wireless and lan connection to work concurrently in Ubuntu. When I am using my 3g netwok then want to use ps3 media server to stream to the tv it just doesnt work! As soon as I disconnect the 3g connection then it works fine with no issues. Surely there is a way where I can surf on the net and use my lan at the same time?
SecretCode
Are you still struggling with this poorestguy?
When you connect your 3G, it sets a default route for all traffic to go via 3G. Traffic to your local LAN should still work as there should be a network-specific route for it, but if your media server's on another subnet it won't see it. The fix is to add another network-specific route.
poorestguy
hey..nope still havent sorted the issue:( the issue is i havent added any subnets manually except for the lan, and the cell c 3g connection creates setting synamically as it dials up.how do you add a specific route to differentiate the traffic?
poorestguy
gees so much for the easy way out.ok i have been lazy.i will add a static route for my lan connection.this should solve the trick right?i just cant beleive its a problem in ubuntu.windows is better :D
SecretCode
To expand slightly on what Grim147 asked for: give the output of
Code:
route -n
and
Code:
ifconfig -a
when you're connected to both
Then it will be easy to say what extra static route command you need.
ponder
You can't use network manager to use to connections simultaneously you git :D
