caroper
- Aug 5, 2003
Hi All,
Not sure if you have this problem, or if it is just local, but this morning I couldn't access any HTTP pages. NNTP, SMTP and POP3 were all working fine.
After restarting the PC and resetting the Router it was still the same.
After 15min on hold to Telkom, listening to volume 3 of "Music to Invoke Stress By" I decided to try the proxy settings.
I entered 196.25.253.13 (any body know what proxy that is?) and up came all my web pages again.
On another PC I set it to dsl-cache.saix.net:8081 and that also works.
In fact that is probably the correct one to use.
I guess if you have this problem you can't read this post,[:I] but it is here now for future reference anyway.
Is anyone aware what the root problem is and or when it will be fixed?
Cheers
Chris
Cheers
Chris
