Belix
- Mar 3, 2007
Greetings all
I've been using an old (2010) IBM 3000 VA rack UPS to power just a 50" LCD and decoder.
It was fine through the 4 hour load shedding, but somehow since the 2 hour load shedding, now dies after about an hour, even with the TV off. It still shows around 2 hours capacity remains, but then issues a battery low alarm and shuts down.
I checked the 8-in-series unit battery pack and found two of the Yuasa NPW45 12V batteries were about 10V.
Swapped them, and two swollen batteries out with 4 new of the same make/type Yuasa NPW45 12V 8.5Ah batteries. (since then I've been told I should not mix old and new batteries, but anyway, that's what I did). They are not a cheap purchase at R1K each...
Thereafter, the UPS does pretty much the same thing, I get about an hour. All batteries show about 12.5V each when it shuts down.
I went into a store that sells inverters, and they said to replace all 8 batteries with their al-cheepo R250 versions.
I was wondering if I should risk buying another 4 of the OEM Yuasa batteries instead, but given the cost, would like to check the UPS is not the issue, but not sure how to without 1st buying another full set of batteries.
Would checking the capacity of the batteries one at a time using some sort of battery tester reveal if any of the remaining 4 are showing 12V, but have hardly and Ah capacity left in them?
