im a dumb f*** OSPF over GRE between links
loosecannon
ok guys BGP well that was easy its unicast and there is nothing complicated to it ...
rip is a bit tricky as it is multi and unicast UDP (224.0.0.9) so to get it to work you must set the tunnel multicast ... simple enough ...
now that ospf bitch yeah it is multicast and uses its own protocol that aint a problem but the dumb bitch dont like having a mismatched MTU so the link never went into full mode ... hope this helps some one else at some stage ...
here is a script for setting up a gre tunnel on a linux box with a private mini subnet that sets the PTP address properly and TTL to avoid other major headaches
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">
#!/bin/bash
#Configure Tunnel tun0
/sbin/ip link show tun0 &gt; /dev/null 2&gt;&1
if [ $? != 0 ];then
SR="100%";
else
SR=`ping -c 3 192.168.99.6 |grep "packet loss" |awk '{print $7}'`
fi
if [ "$SR" == "100%" ];then
LOCAL=`ip addr show dev ppp0 |grep inet |head -1 |cut -d/ -f1 |awk '{print $2}'`
REMOTEIP=`dig +short &lt;HOSTNAME&gt; A IN |tail -1`
if [ "$LOCAL" ] && [ "$REMOTEIP" ];then
/sbin/ip tun del tun0
/sbin/ip tunnel add tun0 mode gre remote $REMOTEIP local $LOCAL ttl 255
/sbin/ip addr add 192.168.99.5/30 peer 192.168.99.6 dev tun0
/sbin/ip link set tun0 up
/sbin/ip link set tun0 multicast on
#Configure Routes For tun0
/sbin/ip route add $REMOTEIP via $LOCAL dev ppp0 table VPN
fi;
fi;
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
