IMATE Jamin Edge VERY SLOW!
Nalith
Hi
I have a Imate Jamin, when I connect using dialup in an Edge region and run any
speed test I'm getting speeds of 9 Kb/s which is slower than normal dial up. Can anyone give me some advice as what to check?
Syndyre
Is this local or international? There have been intl problems on MTN lately.
The Guy
Hi
What ROM version do you have??? start - settings - system - device information
which icon do you have on your device G or E ???
Nalith
Rom Version: 2.13.9.23 WWE (Which was the latest the last time I Checked)
It shows "E", hence the reason I said i'm in a Edge region :D
I'm sitting at full signal also.
The Guy
i have to ask these questions .... Techie 101 ... my monitor is not working .. is it plugged in .. is it turned on ...
Have you tried using another SIM card in the device ????
Nalith
Yip, just did the test now with another SIM (MTN 3G SIM), i'm still getting 30 - 40 kbps which is much slower than 250 kbps that Edge should be giving me. I have also tried it on another tower, same story.
The Guy
its much better than the previous 9 kbps .. MTN Data dude can maybe shed some light on this subject ... i doubt it is the devices
Nalith
I did a few more tests, with my SIM and the 3G sim, seems the speeds vary between 9 to 40 kpbs but never really more than that =(
I have tried phoning MTNSP, they weren't too much help.
internaut
I get about the same throughput when I connect my I-mate up to my PC as a modem and when I use it on it's own. The Network type doesn't make a difference, CellC, Virgin, MTN, all give the same slow throughput with the I-mate. The same sims in my edge data card however gives the "correct" throughput. I haven't really bothered to figure out why so I don't have a solution. :( :cool:
YelloFever
MTN Company Representative
That's interesting
MTNDD
YelloFever
Unfortunatly I have not tried it that way round yet, I will do so when I can get hold of another 3G/Edge device.
Otherwise advise us on the forum where you are area and so forth and the rest of the guys can advise if they having a problem in the same area and if yes then we can investigate via the network
Let us know
MTNDD
Nalith
Let us know
MTNDD
The two area's I have tried is Bryanston (Main and Norman rd) and Midrand (16th Road). Hope this helps, I would really love to get this sorted out. I will have a look if I can check this in more places to see if I get the same speeds and let you know. Thanks for the help so far DD :).
YelloFever
No prob
MTNDD
