The_Traveller
- Aug 9, 2008
Oops...The devil is in the detail....
That's a good inverter, but $$$ ... anyways to answer your question ...
you're right, to add voltage, you need to wire in series.
The advantage of a 48v over a 24 is that you will have extended backup time ... for example ...
If your load is 1000w ...
on a 24v system - 1000/24 = 41.66Ah
on a 48v system - 1000/48 = 20.83Ah
So if you using 12v100ah batteries, then on a 24v system .... 100/41.66 = 2.4 hours
on a 48v system ... 100/20.83 = 4.8 hours
ALL OF THE ABOVE IS NOT TAKING INTO ACCOUNT INVERTER EFFICIENCY, BATTERY DC CURVES ETC. JUST A QUICK LOOK AT WHY A 48V IS BETTER THAN A 24V , BECAUSE YOU HAVE MORE BATTERY.
To get a 48V system, you need 4 x 12V batteries in series. For a 24V system you need 2 x 12V batteries in series. So in order to get double the capacity, you still need double the amount of batteries, so there is no extended run-time benefit.
Whether you configure 4 batteries in series for 48V or in series/parallel to get 24V, you will end up with the same run-time.
Thanks, that's how I had it. I disagree with you on parallel, though, based on what I've read. Parallel doubles your amperage, for a given wattage.
Also, Traveler, I was aware that the system adds resistance etc. I'll allow for that when doing my final budgeting.
The whole idea with going for a very good inverter is having the option of converting to solar later on. There's definitely cheaper options out there. Also, the 3kw inverter has a pretty great 6kw surge rating, so if my (soon to be) new baby needs its milk heated now, I can use the microwave, instead of slowly heating it on gas.
Or I can get a proper genny, running at R25,00/hour, noisy and costs R18k.
Surge rating is for a few seconds AFAIK , but I might be wrong.
1'st question - 24v or 48v? And if I calculate that I need 250Ah of battery life(already accounting for dod), do I need 2 12v batteries in series for 24v(and 4 for 48v), to get the same amperage? What exactly would be the benefit of going 48v over 24v then?
You did see that OP wants to expand as time goes on, right?The whole idea with using more batteries in Series is that your battery cables can be thinner and generally less current flowing and therefore less loss. Good for big installations etc...
Not for Mickey Mouse installations like we are talking about here.
All you do by going the 24V route at this level is adding expense. To do the same job you now need 2X 50Ah batteries...
I hope I am making sense![]()
There's a reason why people don't use 12 volts for solar installs and that is because of safety and efficiency.
If he starts off with 12v now he will have to buy a new 24v or 48v inverter when he goes bigger.
Good luck trying to not burn down your house with a 12v system :twisted:
its fairly simpleHi YingYang. I'm very interested why 24 or 48 volt systems are preferable for solar systems and 12 volts could be dangerous. Could you please explain as I am thinking of using solar panels in the future. Many thanks![]()
its fairly simple
Example: 60 amps at 12 volts will melt wires and perhaps kill you under certain conditions. 30 amps at 24v will tickle you perhaps. 15 amps at 48v you won't even feel!
All three of the above will give you 720w. However 12v=thickass wires which can burn schit down. 48v=thin wires and you don't have to worry about a thing.
Ask these guys @Arthur @lsheed_cn
its fairly simple
Lead Acid droops quite a bit under load - voltage dips quite a bit under heavy loads.
So traditionally you'd go with a larger voltage if you have heavier loads so that you can supply whats needed, as more batteries will equal less current draw across each battery, and hence less droop.
Thats the main reason, cabling is secondary (cheaper to run higher voltage / lower amps than higher amps / lower voltage)
Other battery technologies are better, and don't have that issue (eg Lithium)
