richjdavies
- Sep 9, 2013
15 Amps will definitely kill you.
But you won't get 15Amps through your body from a battery.
http://en.wikipedia.org/wiki/Ohm's_law
V= IR --> so I = V/R
A battery is known as a Thevian Equivalent -- it effectively can give (for very short periods of time) unlimited current at a particular voltage, it is voltage limited. The resistance across your body is HUGE and depends more on the very final bit of the connection -- wet hands vs. dry hands etc (just a quick test on a multimeter told me 100k-2.5m ohms)
So at 12V a battery will only be able to give you 0.12mA (12/100,000) = 0.00012A. But that's still enough to REALLLY hurt you and possibly kill you. But it's the tiny amount of current that will kill you - by upsetting your heart rhythm, it won't burn you to a pile of cinders like the grid will.
People don't get killed by electricity in the way they do in the Movies:
http://gizmodo.com/5262971/giz-explains-how-electrocution-really-kills-you
