iPad 2 will be Cell C friendly - supports UMTS 900MHz
Madhawk
Will you be able to use the normal sized speedstick Cell C Sim card or does it have to be a Micro Sim card?
EDIT: Oh crap, it's a Micro Sim card.
rapidblue
Yip, Micro SIM, but I guess we'll just cut it down to size and use a SIM adapter if we want to use it in the speedstick again ;)
morkhans
A MyBroadband
Super Moderator
Cell C do have MircoSIMs, so no cutting required.
Pavan
Woohoo! I'm sure Cell C will come out with a great data package for the iPad2... I hate the lame deals (sometimes more minutes than data lol) on the iPad and Galaxy Tab currently being offered by MTN and Voda...
adamr
Mmmmm .... Waiting for my ipad 2 and will be sure to get the microsim for it
jasweb
Yes and since the speedsticks have both normal and micro sim slots there is no need to use an adapter.
I think you are thinking about MICRO SD slot in the speed stick. No micro SIM :/
Get a Wifi 3G router to use with your iPad (and Phone) when at home. Are you really going to surf on 3G with that big device (else just pack in your 3G router in your backpack as well)...
fxit_man
So has anyone confirmed this for interest sake? (I'm with VC anyways, just curious)
shaunl
Cellc internet bundle to use for iPad2
I currently have the Cellc prepaid internet bundle with 2 GB data per month, i have just got an iPad 2 and was wanting to know if i can sim swop this bundle to be used on the iPad2>
Looking at the specs it looks like it should run 100% on the cellc network (including 3G and HSDPA speeds)
i have bought a new sim and cut it to size, when i put it in the iPad it picks up the cells network perfectly.
Does anyone know if i simply request a sim swop to the new sim if is sorted - (the instore people cant seem to confirm this)
