LCBXX
30-odd years.Last thing, old complex or new? Also is there separate data lines or do I have to run a cable along side openserve in the **** pipe cause let me tell you when that pipe blocks and they try to pressure wash the pipe out no one gonna have net. If the trunk work has sufficient space then sure I'd roll out a network and if I can pipe a DFA line there sure, probably be cheaper or I can throwup a mini tower at the guard station of the complex and installer loco's around the complex for even further saving. Also who owns the data infrastructure of the complex did Openserve deploy it or was the complex involved with it, cause Openserve doesn't share (very very good point)
Openserve offered to install their infrastructure underground, using existing underground infrastructure accessible via manholes, as well as installing the customer/home connectivity using existing conduit/etc. This approach eliminated any impact on the external aesthetic of the homes.
We agreed that the option of 2 or more fibre providers in the complex is to the benefit of all homeowners but Vumatel wanted to do it their way only. They did say that they could deploy underground as well but that cost was prohibitive.
Sure, the Openserve rollout did take longer than usual as Openserve had to do work to repair/clear certain underground areas. I would say it was worth the trouble as 80% of the homes subscribed to 100Mb+ internet services.
