Hi Guys,
I see there are quite a few people on here that had/have issues with getting routers setup correctly for iBurst but none of the threads seemed to provide answers to my questions.
So here it goes...
My setup is as follows:
* Got a ZyXEL P660HW-T1 router (it has an ADSL modem built in).
* Desktop iBurst Modem connected to one of the ethernet ports.
* 2 desktop PC's connected to the ethernet ports
* would also like to connect a notebook (that has Wi-Fi built in).
I'm trying to find out whether i can even share my iBurst connection using this router??
I know you can use Internet Connection Sharing in windows, etc. but that isn't ideal as i don't want my web connection to be dependent on any one PC. I want to be able to just connect to the router and access the web from there.
Now on the router, I've gone through the 1001 settings and setup the LAN. But as for the WAN side of things, it doesn't seem to work - router doesn't seem to invoke the connection.
So now I'm struggling to get the router to invoke the connection (as opposed to having to invoke the connection using iBurst dashboard on one of my PCs). Is it possible that the WAN settings on the router are are essentially only configuring settings for the WAN (dsl) port of the router (and the modem is connected to normal ethernet port)?
Anyone have any ideas? I could obviously buy another router but would like to first determine whether i can even achieve my desired setup using the ZyXEL router.
Please help!!!
So here it goes...
Please help!!!
