Joburg power lines do not give off harmful radiation – City Power
ToxicBunny
Oi! Leave me out of this...
Someone needs to stop interacting with the real world...
Easter Bunny
all my jackets have a space blanket inner sewn in to prevent these things.
a foil hat also helps.
Messugga
Rode my mountainbike under so high voltage power lines the other day. It induced a current in my seat's rails, which when my thighs touched it, gave me a bit of a shock. It felt like a needle pricking my skin. Quite an interesting experience.
Harmful? I wouldn't want to live near the high power lines.
OneKnight
I remember Richard Hammond sticking a fluorescent light into the ground underneath high voltage power lines, and it switched on.
Cannot find the clip now, but here is an example.
[video=youtube;tRLNNrHg2QE]https://www.youtube.com/watch?v=tRLNNrHg2QE[/video]
Gnome
When I walk on a carpet and touch something metallic it gives me a shock. Harmful? Not sure but I'm considering getting rid of my carpets.
I have other things that also generate a charge in metallic conductors and considering getting rid of them also.
Tesla is a magician and transformers (which rely on electromagnetic induction) is black magic that causes cancer.
38.5% of the population get cancer and they have all been exposed to transformers. It confirms the theory.
Idiosyncratic
There's a solution to this - all people like yourself get to live under HTs at a discount while people like him can live elsewhere.
Gnome
So they place a light in the ground near a cable that uses a grounded neutral, with a very high potential and a large electromagnetic field surrounding it.
And it lights up?
Amazing, it is almost like everyday household items such as transformers are based on this very same principle but when I see it here it is 1000x more scary and probably causes cancer.
Gnome
High power transmission lines are ugly.
And if it breaks, it is a serious danger and serious fire hazard.
That is why they don't build houses directly underneath them.
And yes, the potential difference between the cable and ground is enormous.
So you get things like corona which is noisy + you can get a discharge to ground in the case of serious moisture.
But the science behind it is very well understood.
The principle of induction is used in everyday life.
I have a wireless cellphone charger that does the same thing.
People are installing seriously high power stoves now that make use of induction.
And they heat up actual pans, that uses WAY more power than those silly little bulbs.
They probably cause cancer too :erm:
I guess the sound of corona on HV lines makes them far more menacing even though a common household induction stove emits just as much energy albeit in a much less flashy way
