Just undervolt with Afterburner and have a "low power mode" you can toggle when you want?
Don't know much about undervolting but will look I to it.
Msi afterburner dial down the max power sliderI'm currently gaming on a Ryzen 3600, RX 5700, 16 gigs of ram, 2 SSDs, and a Gigabyte Aorus B550-m Pro-p motherboard. Generally I play esports titles, but I do enjoy having the option to play some games like Cyberpunk and Hogwarts Legacy from time-to-time. With esports titles my PC uses 150-200 watts, but with more demanding games, that usually doubles.
We've recently gotten solar and I was wondering if there's a way to enjoy the same level of gaming experience (or better) while consuming less power, as if I go for a few hours with Cyberpunk or another high end game, that can drain our battery quite a bit at night.
So I was thinking of either specc'ing an energy efficient desktop machine, or looking at a gaming laptop, but I wasn't sure what would be the better choice?
Firstly, make sure you have installed and updated your chipset drivers for your motherboard. Those install custom power plans that you can switch to in Windows. Ryzen Balanced is recommended. You also need Radeon Software Adrenaline installed and updated.I'm currently gaming on a Ryzen 3600, RX 5700, 16 gigs of ram, 2 SSDs, and a Gigabyte Aorus B550-m Pro-p motherboard. Generally I play esports titles, but I do enjoy having the option to play some games like Cyberpunk and Hogwarts Legacy from time-to-time. With esports titles my PC uses 150-200 watts, but with more demanding games, that usually doubles.
For playing on the go and won't tripI travel extensively for work and usually wield a high spec gaming laptop (ROG/Alienware). I use a lot of VMware in my work which justifies a high end machine (SSD and plenty of RAM). The happy outcome is it becomes a justifiable business expenseHowever, I have run into a snag... power consumption. Airplane power supplies trip at 50w. This means that on those long journeys, I get 2-4 hrs of usage (Word. Excel, Outlook, possibly some offline Netflix) and then nothing. No charging on the plane and inadequate time between connections to catch up. In the modern era, extra batteries are not popular and I almost had one confiscated in S America (expensive). So, I am looking for guidance on my next lightweight laptop - SSD, 16+ GB RAM, good graphics (for games like wow), 5G WIFI, USB 3.1, low power supply (less than 50w). Does such a beast exist? Thanks for your help
