MacBook Pro 13" Unibody 2010 Hard Drive Cable
Vohligh
Hi guys,
Does anyone know where I could purchase one of these cables?
Thanks in advance
bwana
MyBroadband
Super Moderator
Was going to suggest ifixit.com but they're currently out of stock. I had a problem with my HDD - it could have been the cable - but ended up replacing the superdrive with a drive bay.
Vohligh
Thanks, have you purchased anything from ifixit.com before? Ah cool, so getting a caddy will void the need for a hard drive cable replacement :)
bwana
MyBroadband
Super Moderator
No, I haven't purchased anything from them but I would if I needed something. They're reputable. :)
vinodh
Try http://www.powerbookmedic.com I used them to buy that cable for my 2011 MacBook Pro as well as an IR Receiver I needed for a Hackintosh media centre and they delivered both items with no issues.
koffiejunkie
I've bought from iFixit before - had no problems. The only downside was the shipping cost.
