Somewhere I read from the Vodacom supplied software does not allow you to use the card for making calls like the MTN one does.
The answer is to download the Huawei generic software that does allow you this. Here is the link for the version that I am using http://www.huawei.com/mobileweb/en/file/download.do?f=2158&ctype=1he Once you have installed it you then create different profiles for the diffferent sims that you have. It works well.
Caution this file is large so dont use your card to download it -- 67 507 KB
