Making up a Hi-Speed RJ11 ADSL / VDSL cable
MidnightWizard
Time to start working on those New Year resolutions ..... :)
I am looking for RJ11 Modular connectors similar to what one gets with the RJ 45 connectors
See image for example
This is a made up cable --
I am however able to make up the cables myself but need to know where to find the bits I need
Shielded twisted pair Cat5e for Telecoms cable as well as the special molded RJ11 connectors.
I have done a quick Google but cannot find anything ?
I would be OK to purchase a made up cable IF it was similar to the one in the image ( same specs ) AND was at a reasonable price.
Would however prefer to make up my own -- IF I can find the necessary components ......
Anyone know of a source ?
MidnightWizard
Close -- but not a Cigar
I have bought RJ11 connectors from The Networking Warehouse before: http://www.tnw.co.za/
Thanks for taking the time to look and reply
I already have quiter a couple of the RJ11 connectors as shown at TNW unfortunately they are not the molded type as shown in the image posted -- they are not that common being specialised.
ponder
How are you going to do the moulding? Moulding is done in a factory.
MidnightWizard
Moulded
Moulding ( MOLDING according to US English ) is perhaps misleading
The conectors I have seen ( for RJ45 ) look already semi-moulded and are crimped in the normal way.
Just that when you crimp you also crimp the "moulded" portion
The finished product looks just like a factory moulded connector .......
THESE are what I am looking for .......
WAslayer
You sure you not thinking of these little booties you pop on the cable and pull over the jack once you crimped the cable..?
My googling is failing me in coming up with anything that matches a 'crimp it yourself moulded jack' and why they would ever make them to begin with..
MidnightWizard
Shielded Boot
Nope
Also have quite a number of those
Why would they make them -- for people that need something more than the stock standard
OK
This is what it looks like
https://www.vpi.us/cat6a-plugs/cat6a-plug-shielded-boot-820
I see there are quite a number of similar products from different companies
I am not sure where the ones I saw came from ?
Was definitley SA supplier -- will have to check
SO
THIS is what I am looking for for an RJ11 6P6C / RJ12
MidnightWizard
PlugnBoot
OK
Here is another one -- with animation
http://stores.ebay.com/EASWIRE
On that page have a look at --
500x Cat6 Cat.6 Network GigaSpeed Connector RJ45 Modular Plug'n'Boot+Wire Loader
Plug and [integrated] boot seems to be newest "hot-number" ?
