Does anyone know where I can get the manual for this inverter:
Anyone have feedback on it also?
Thanks! I am looking at using it as a UPS to keep my USG Router, Switch, two POE APs and Media server online during load shedding.Mecer 2400VA Inverter (Community Support)
This Thread is for the Mecer Inverter only. My personal opinion on the unit: Seeing that there are lots of question and in lots if threads, here is my review/input on the Mecer Inverter. Instead of reposting I'll just reference here. I'll add more info soon. This should give you an idea what...mybroadband.co.za
Yeah, it's perfect.Thanks! I am looking at using it as a UPS to keep my USG Router, Switch, two POE APs and Media server online during load shedding.
The manual is pretty basic - what do you want to know?
Also, I have the 720W. It's good, when running or charging there is a mild coil buzzing sound and some fan noise. I wouldn't want it in the same room as where i'm working.
4700 total when u buy them separate or together with a box and trolley ?I wanted to see its outputs etc, also what options the screen has. @RedViking thread gave me most of my answers. I have all my network equipment in my bedroom but if its noisy i might need to look at moving it. Makro has got a special on it with Ellies 12 V 102 Amp Royal Deep Cycle Battery for R4799
No separate.4700 total when u buy them separate or together with a box and trolley ?
I got one too today.No separate.
@RedViking do you charge at 10amp or 20amp?Yeah, it's perfect.
Luckily this Inverter does not have a software interface.Wouldnt trust Mecer, they are just rebranded god knows what and the UPS software is garbage.
Would rather buy Eaton, software is tops.
10amp. We only always have 2 hours loadshedding a day fortunately.@RedViking do you charge at 10amp or 20amp?
Its in our bedroom, and the noise is a bit much, it would be much better in the closed spaceWhy not keep the inverter and battery box together and run the output up the cupboard with an extension?
your battery cable between battery and inverter has to be as short as possibleI know the cable from the battery to the inverter needs to be as short as possible but I kinda have a sticky situation...
My router, switch, POE and PI is all in the top of the cupboard (I have built a shelved space). From my understanding is that the battery cant go in the cupboard. Whats the possibility of running a cable for 4m from the Inverter in the cupboard to a battery box on the floor? What would the thickness need to be?
720watt continuousSo this question is a little late, but I am also looking for the manual to determine if this is 720W continuous output or 720W peak. I want to run my TV, audio receiver, router and CPE of it and definitely do not want to tax it too much.
Hi, I installed my inverter but the power does not switch over uninterrupted. The reason I purchased it is so my modem and DSTV stay on to retain the memory etc? What can I do?Does anyone know where I can get the manual for this inverter:
