alan vicente
- Jul 30, 2020
Hi how do i change the mecer 2400VA (1440W) mecer inverter bios/firmware settings to charge from my solar panels instead of the built in charger?
There seems to have been a design change to this model as the solar controller is now seperate from the unit where as the manual reflects that the controller was previously part of the ups.Sold in south africa as a mecer model: LOBO 2400/ivr-2400LBKS
There are no external plug in points on the inverter either rs232 serial or usb connector to load operational parameters.
Does this inverter use jumper switches on the board or must i remove the inverters cover to discover a plug in point?
The inverter front panel is not seeing my solar panels and reflecting that it is charging of my built in charger.
I am using the recommended solar controller for this unit. model EXT-SCC-2400LBKS.
Please note i am an ex pc technician trying to help myself with this issue so finding my way around the tricks and traps slowly.
Last point.I have checked wiring etc and appears to be correct.Two solar panels 360 watts each connected in series.
