Last weekend I bought a Mecer 720W Inverter and a 200ah Sun God gel battery. I am using the battery cables that came with the inverter.
Today during loadshedding I tested it with running the xbox and tv and after about 1h30 the inverter started beeping for low battery but the inverter shows there are 3 bars battery left and my usage is only on 1 bar. While it was beeping, it showed two bars left, basically 50%, but then I switched off the xbox and it showd 3 bars power left and stopped beeping.
I have an Xbox One S, 48" curve tv and a soundbar plugged into a surge protection plug and then into an extension cable into the inverter. I also have a macbook air plugged into the inverter.
This is what I'm running on the inverter:
- 2015 Macbook air: 36w
- 48” Samsung curve TV: 135W
- Xbox One S: 90w
- Soundbar with subwoofer: 50w
- 27” Samsung monitor: 36W
- 21” LG Monitor: 24W
Based on my calculations, my battery should be lasting a few hours unless I am missing something. Why would my inverter start beeping for low battery after 1h30 when the inverter shows 3 lines left on the battery and only 1 line of load?
Thanks for any help/feedback/guidance
- Xbox One S: 90w
