If you're interested in creating something similar to SeattleWireless in JHB, join JaWug.
Exactly the same concept.
Step 1) Find your GPS co-ordinates (use a GPS, Ananzi's Road Maps, or even Sentech's Zonelocator)
Step 2) Plot your node on http://www.nodedb.com/africa/za/johannesburg/? (If you're in JHB)
Step 3) Visit http://www.daffy.za.net/jawug/ - register yourself as an owner.
Then look on nodedb to see if there is someone near you (1 node, 20 nodes, the more the merrier). Contact them and arrange the link, you'll need to check that you have Line of Sight with them.
Eventually, there will be enough of these little networks, they will all merge into each other and we'll have JHB covered.
Tell all your friends...
Come and join us..
