Mini UPSs and compact battery banks can help to keep you online during load-shedding
wingnut771
It’s about 50% discharged after 2 hours, hard to accurately say.
It’s on sale at the Vodabucks store
Nice find Prof!
32.5Wh/2=16.25Wh
16.25W/2=8.125W per hour
This is why I say you can't take the value on the router power supply as the load, that is just the max output of the power supply and is usually much less in reality, so you see @William1102, it's not 18W, but rather 8W.
William1102
Nice find Prof!
32.5Wh/2=16.25Wh
Thanks for the insight [mention]wingnut771 [/mention] looks like I’ll take this volkano unit it’s a steal and probably turn off 5Ghz on the router to conserve power
Edit : can you use the vodabucks store as a non Vodacom customer
ProfSantosh
Nice find Prof!
32.5Wh/2=16.25Wh
100%. The power supplies are generaly over spec'd and very off-the-shelf branded items but it is a good guide.
@William1102 I don't think these Mini UPS's have a long life span so don't over-spec and waste your money because you are bound to have to replace them in around 2 years (NB is just my guesstimate).
wingnut771
and the power level of 2.4ghz also helps. :thumbsup:
wingnut771
Do I have to sell my soul when I agree to vodabucks store T's&C's?
William1102
True you have a good point , this is why I’d rather buy the Volkano @R349 Or on takealot an UltraLan @R499
Mask
Sure :)
Base unit
https://www.communica.co.za/products/psu-cctv-12vdc-3-5a
Battery
https://www.livestainable.co.za/product/bslbatt-12-8-7-5ah-lithium-ion-battery/
Wanted to get this one but the current spec was not nice.
https://www.livestainable.co.za/pro...lithium-iron-phosphate-13v-8ah-104wh-battery/
Discharge Current 1.44 A continuous vs 10a or 15a if I remember correctly
Thanks for this. I am looking for something basic to simply keep my air fibre setup going which has the router and a power supply for the dish/receiver? So this should work, correct?
