MMS Settings for HP 6915
YelloFever
MTN Company Representative
Nope still not sorted can't get or send mms
Did you PM your details to Snakepit?
If not send them to me and I'll get someone from 1555 to give you a buzz and help you sort this out
MTNDD
squidge
Sorted
Hey Mtn got hold of me and seems to be working great - Thanks a million:D
squidge
MMs Settings
If you follow the instructions from the link to HP 6515 settings and where it says use MTN-MMS use MTNMMS without the dash and make sure you get your punctuation correct it seems to work.:)
YelloFever
@squidge
Thanks a lot
MTNDD
Bulldog_rsa
I have tried to do the above and have not been able to get my MMS to work on my HW6915. Is there anybody I can call or see at MTN that can help.
jpgrobler
Hi
I am om vodacom and the only way I got my mms to work was to create a new connection to use for mmsíng. THe autodetected vodacommms settings did not work no matter what I did. MAybe it is needed for mtn also.
Folow the instructions in the mentioned posts to create a new mms connection and edit the other mms settings likewise?
I had to phone vodacom once to ask them to reset my sim profile - deactivate gprs & mms & wap and reactivate it. It worked.
