weallloveleeds
- Jun 22, 2006
on vodacom 3g........ after a while, i can see the small terminal window thing showing the connection in the bottom corner on the task bar go totally dead. so its no longer highlights for send/receive in light blue.
So i try a site or whatever and it doesnt open and i have to then disconnect/reconnect then it works fine again for a while.
This used to even happen on my telkom dialup line but it hasnt done it in ages. Now is this a vodacom 3g fault or is there some setting i should change in modem settings or even on my phone?
Anyone????? thanks!!
