Okays... a few more hours and no progress. Even worse I will be out of the country for the next month or so - can't do much then.
Just some background - I also run Win98SE (on a laptop, hav also XP Pro on it but leave it intact as it hav to connect to company intranet) and have a Belkin F5D7230 (from UK) wireless router, incorporating 4port switch, 1 WAN and 802.11g for wifi (so not really ancient technology). I bought the Belkin cos I was a few years ago really impressed with a mouse from them... and also on a opinions site like epinions.com the router had good scores. Including good marks for ease of use. Sheesh - supposed to hav a 3 minute setup!
Anyway... router WAN options are:-
1) Dynamic (require host name)
2) Static (require ISP fixed IP)
3) PPPoE (require Username+password, optional service name, MTU)
4) PPTP (specified for European countries only, need settings)
5) Telstra Bigpond (Australia only)
In manual I read that PPPoE is actually Dynamic PPPoE - so thats OK.
On router setup there is a "Connected to Internet" indication. If I choose 1) Dynamic the connection is failed. Used host as dummy www.sentech.co.za. If I use 3) PPPoE router reports "Connected to Internet". I played around with this - I messed up my username and still it reports as connected to internet!!! So either my username+password is of no importance, or else its lying.
I observe with USB that a proper authenticated modem connection is indicated with solid green light on modem. With LAN/PPPoE the green keeps on flashing, even though its supposed to be connected. No wonder I can't get traffic through, so again I think its not really getting my authentication info... or don't get the "activate the darn connection please" indication.
On PPPoE I tried to change MTU. The router is limited to settings between 1440 and 1454... so my 548 is offscale. Left it at default 1454 (lots of warnings not to touch this default setting)
In Control Panel/Network settings I changed adapter for "PPP over Ethernet" for the network interface to its minimum value... think that was 576, can't go lower. I think DrTCP is also pointing to this MTU value. No changes observed.
What is RWIN - don't see it on DrTCP either??? My RWIN is about 108x1.6x128/8=2764. Don't know what to do with that.
Dumb question.... but:-
My router LAN IP is 192.168.2.1 (default setting). I see on the router WAN setup that WAN IP is 192.168.168.220 (not changeable, comes when selecting PPPoE). It says the default gateway is 192.168.168.2.
NOWWWW... how do the PC know what path to follow to 'find' the internet??? The router setup only said to make sure all tick boxes is cleared on the PC LAN Internet\Connections settings eg. Automatically detect settings and using of Proxy server etc.
On my LAN setup the local IP is 192.168.2.2, and no gateway is specified (did try router IP's no success either)... and I can't see any mapping specifically to the router. How is the PC supposed to know where to look for internet??? I think the PPPoE is for comms between Router and Modem and not for comms between PC and Router ???
I seen somewhere a posting of something like a "contracting service" (possibly totally wrong spelling, just looked something like it!) that needs to be running - in my simple mind something like a USB conrollers... something that detect a new connection and manage addressing of such devices.
In my opinion my PC have no idea that there is a router connected to it, and absolutely NO idea that there is a modem on the other end that it is supposed to communicate with!!!
So that brings me to the thought that somehow the 'connection' still needs to be manually initiated with a 'dial-up' type activation. When installing MW with Ethernet option the MW dialer icon appear on the desktop. When trying to open it it says modem can't be found. In router setup they described to use Start\Run\RASPPPOE to create a PPPoE dialup connection (think this is more applicable for ADSL where modem is part of router box). Again there is a place for Name and Password but then it times out and says remote did not answer.
So in brief...
I don't think MW modem cares much for user authentication it currently receives from Router via PPPoE - thats if it receive the information at all; seemingly its not reaching modem (green light keep flashing). Possibly need some sort of connection activation by User eg. a dial-up connection initiation. My router do not have 'always' ON settings to keep trying to activate the connection.
Secondly I wonder how the PC is supposed to know about the router located at 192.168.2.1 ... and the MW modem that is connected further downstream on the WAN port. You said the PC will not detect the modem but it should see the connection. Are not happening here so far.
Maybe you hav some ideas to confuse me further ???
Thanks again for your input - I'll probably follow this up with new enthusiasm in a months time when I return. In the mean time I will monitor this posting looking for ideas!
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dbnnet</i>
<br />cluney,
Many of the decent routers have three settings, "Always on", "Manual" & "Network Activity".
Most have a web interface that offers an overide "connect" and "disconnect" button.
I'm concerned that you don't have a "dynamic" option. This is a must in my opinion.
As for drTCP, this is important, and your problem may well be a MTU setting that is too high.
(http://www.dslreports.com/drtcp Latest version is 2.1 )
As for your MTU of 548, I see that Noswal is using Win98SE, and had a low result of 576.
This is probably operating system related. But I have not had the chance to try this myself.
As for using USB ... the IPW drivers are supposed to over-ride these settings, but I have some
doubts about this based on my own experience.
As for detecting the modem.... no, windows can only see a connection, not the actual modem itself.
Hopefully someone like ProAsm will write an interface one day.
<font size="1"><font color="black">Bay of Plenty :</font id="black"><font color="blue"> Signal 48% - SNL 17 - ber 71% :</font id="blue"><font color="green"> D-Link DI-604 - PPPoE :</font id="green"><font color="orange"> 8dBi Patch Antenna :</font id="orange"> Firmware 4.2.1.8</font id="size1">
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
