N95 slider problem
lion_fish
looks normal to me?
Although the soubd from pressing the one sound doesnt sound normal.
Ecco
I had the exact same problem. And my friend who got his phone 3 days before me didn't have that problem.
The noise when you press on the keys on the slider is really irritating. Would bug me the most when typing sms's and i had to press the "c" key. From your pic i see the gap is more prominent on the left, mine was on the right hand side.
Unfortunately my phone got stolen, so dunno how to help you. But at least you know that other peeps did have the same issue.
3Gee
Slide problems are very common with the N95 , take a look on the net .Its basically down to poor build quality
tony2007sa
nokia slider phones are all made of poor quality that's one thing i notice..their build quality is horrible these days:mad:
tony2007sa
is it true that the plum have the better build quality than the sand? or is the sand better?what colour was ur n95?
tony2007sa
oh ya, and what pisses me off is that when i took my phone back to mtn..their response is that its normall?! wtf? if it is normall then how come some people dont have this kind of slider problem??
Ecco
Mine was the Plum colour. There was a slight gap, bit not really one that is easily noticeable.
Doubt you gonna get that fixed, might have to just live with it.
The Guy
This is a problem with almost all devices that have Slide out keyboards. I see guys flicking them open and closed constantly, without even thinking about it. wear and tear
dlk001
I got the same problem with my slider. I've seen a couple of E65's and 6110 and they are all tight sliders.
Apart from lose slider, I've been impressed with my N95's built quality.
tony2007sa
was your gap bigger or smaller than mine??or about the same? can you guys please share some pic of your n95 i wana know how all your n95 looks on the slider..the gap etc...thanks
tony2007sa
thanks can u show me a pic of ur n95 as well pls..i just wana see if yours have the gap problem also..lol
NoADSLyet
I am sure mine is bigger than Yours! anyway regards the cell gap I have two 95's, the gaps are different. Both slider seems to be too loose and see-saw across for example left top to righ bottom when keys are pressed when closed with a accompanying click/clack feel and noise
tony2007sa
can u show me the pic? yes mine also felt like that ! when u press the top (next to 3g cam area) the bottom part of the slider actually opens up a little...damn.. i wish the n95 has the same build quality as the 6110..the 6110's build quality is excellent...
Ecco
Mine was stolen. Sorry dude, no pic.
dlk001
I can fit 5 A4 paper into the gap. Thats' about 1mm gap. When pressed, it makes a clicking sound.
