NASA will send a helicopter to Mars
UrBaN963
Why not just ask Matt Damon to build one out of poop samples and rusty potatoes?
ab-user
Droning on Mars. Hopefully it will go on and on and on...
ShaunyCT
As far as I know they not even able to land on the moon. In actual fact nobody can. We are stuck on earth.
Google Flat Earth. We have been lied to.
eg2505
They probably already have a base there
Im sure they add a red colour to the mars rovers lenses so it appears red,
probably looks much more like earth then people realize.
I dont trust Nasa, and what they selectively feed us mere mortals. (secrecy officer job was recently advertised)
as well start a panic if we find out Mars looks a lot like earth.
daveza
Due to the much thinner Martian atmosphere, the blades of the aircraft need to spin about 10-times faster than those of a normal helicopter to generate lift.
The Rotor RPM of a typical light helicopter is between 440 & 460 RPM in flight, and at this speed there is a centrifugal force in excess of 4 tonne trying to wrench each blade out of the rotor hub.
So they are going to make a helicopter with rotor speeds of 4600 RPM?
Compton_effect
They already have. The clip shows one flying in a test chamber simulating the same air pressure as Mars.
