Need a cooling solution
fabianzaf
Hi,
I own a Intel Server Board SE7525GP2 chipset + SC5275-E chassis + 2 x Intel Xeons 3.0ghz
Currently the stock standard cooling is somewhere around the same dB as a Vacuum cleaner and I unfortunately dont have a server room to place it in.
For this reason Im looking for other cooling options like Water cooling. I need a solution that does not require any cutting of the server box and that is considerably softer than what I currently have.
If anyone has a solution please reply to this thread.
No "Intel sucks" please - I've had enough of that from people.
Thanks.
|tera|
Master of Messengers
I don't know much about servers, so if my reply is a bit too n00bish, I apoligize, what about a good heatpipe? Or do you specifically need watercooling? With an exhaust and a good heatpipe on the cpu it could make a huge difference, I've heard of Amd X2's that run 15Celsius on a setup like that.
I like Xeon's although I'm an AMD fan, I think it is the best manufactured and well thought out processor in the history of pc's ;) just my 2c though.
werner
the rear fan is 120mm x 38mm, so you could replace that with a generic 120mm x 25mm unit.
the front fan by the hard drive bay is a 92mm unit, also replaceable with consumer units...
there is an option for another 3 fans, so not sure what you have in yoru system, but the others are also 1x120mm and 2 x80mm
that said, the fan SPEED is controlled by the intel server management software,
see this pdf ftp://download.intel.com/support/motherboards/server/chassis/sc5275-e/sb/sc5275_tps_ver_12.pdf
at around page 21..
do the xeons have active fans on them? or is it passive with a shroud to channel air over them? if it is passive then i wouldnt mess with case fans to much, but if they have active fans and the machine isnt loaded to the max, then you can play with the case fans a bit..alternatively, contact your intel rep for this part number:
APTWKT2COOLKIT
which is the "quiet" cooling kit for that chassis (as long as your heatsinks have active fans)...no idea what it contains though..
Nokkie
Never ever use watercooling in your pc i wouldn't trust water running through my system! I bought a big Antec case which supports 5 120mm fans. 2 extractors on the side panel.
all of them are Zalman they have the best cooling fans and other accesories.
I'ts also worth to get a few Hd cooler bays and a extra heatsink or heatpipes. To give you an idea I run atm a 4000+ amd 64bit cpu and get arrround system temp 25c and 38 for cpu while playing games. all the fans speeds runs at 2000 rpms
previously when i didn't have these my system temp was 55 and cpu 65c so it does make a huge difference BTW the chasis also makes a huge difference as well. you must get a thermalate chasis too...
hope this helps
