Need help confirming adsl fault
kb
Could anyone with an adsl line confirm that the seti@home application is no longer able to upload results to the server when connecting via adsl.
Application available here: ftp://alien.ssl.berkeley.edu/pub/setiathome-3.08.i386-winnt-cmdline.exe
This application currently works via dial up but not via adsl (was working on adsl until about 3 weeks ago). If confirmed seems like telkom has disabled a perfectly legitimate use of their adsl service.
ASnogarD
Need more info...if you were capped due to exceeding your 3 gig limit, then yes the international Seti program will not work properly.
I would suggest that IF it is not a cse of being capped you post your tech problem in the relavant tech section.
