need Help setting up an HTC Tytn on MTN 3G
Sapphiron
Hi All
I have my brand new HTC Tytn now on a MTN Procall 220 contract
I'm having trouble setting up it's 3G connection (basically i have no clue)
i did some googling and it setting up WAP by dialing *123# did not work.
Need Help
what are the 3H settings for MTN
specifically
access point name:
username: (maybe my cell number)
password:
Domain:
* Sapphiron fiddels in the background while considering his question
HEY GOT IT WORKING!!!
I went to add new modem connection
settings I used are as follows
Access point name: "internet"
username: <cell number>
password: <blank>
domain: <blank>
maybe the mods would like to sticky this little how-to or something
BEB
That would work but you can also download a cab file from http://www.leaf.co.za that will configure these settings as well as the MMS settings for you. You will need to register before being able to download the file. They also have documents with all the settings if you want to do it manually.
atmosphere
Alternatively, with a bit of searching on this forum you will find a "not so small" thread with a fairly moderate amount of valuable information....
