need help with merlin u740 card
[OUPA]MrNutz
Hi Guys.
I've got a customer with a massive problem...
i can see this is all pointing towards re-doing XP but anyway - lets try.
-Customer has got an LG notebook
-has got the Merlin u740 3g/hsdpa card
problem phoned in : his 3g/gprs doesn't dial up ...very sketchy hey.
when inserting the 3g card - you hear correctly 2 sounds (like when u add PNP hardware) - one for the 3g and one for the wifi part of that card.
as soon as you start the vodafone mobile-connect app - in the left bottom corner u get:
not connected
searching for merlin u740
not connected
....i've checked in device manager - it gets a comm port - and it gets added to the modem section (without yellow or red marks on components)
HOWEVER...
i cannot run a diagnostic query via control panel - it fails
i've uninstalled the whole software set , deleted the \prog f \ vodafone ect.
not helping..
i've changed laptops...yes - then the card works..
so what is screwing this card around - i've "cleaned" the "environment" for a reinstallation - but negative...its not working.
any 2cents b4 i have to redo XP :D
thx
vodacom3g
Vodacom Representative
[OUPA]MrNutz;764764 said:
Hi Guys.
not connected
not connected
HOWEVER...
not helping..
thx
Resource clash maybe? Anything else in Device Manager with exclamation marks?
Try and disable / remove drivers for the built in bluetooth and WiFi, and then try again.
Are you on SP2?
[OUPA]MrNutz
hey v3g - thx 4 the reply
well - i've inserted a seperate wifi card - which works 100% ...
laptop only has 1 card type slot.
yip - xp pro with sp2 - all latest updates.
have also done the total disable of internal bluetooth and wifi - no change
so seems like its gonna be loooong night :)
vodacom3g
I find a light sprinkling of garlic sometimes help with Windows driver problems....
Have you tried to connect via the VMC dashboard?
[OUPA]MrNutz
live in a very small town - sasolburg - only got 3g here for about 2 months now - doing I.T support - so i'm only getting a feel for the software just now :)
[OUPA]MrNutz
soz - TOTAL noobness from my side
it's the normal red application ....yes that i know - wasn't aware it was going around called VMC
anyhow - windows is being SERVED as we speak
