Cassady
- Oct 27, 2011
Hello all,
Bought this from Takealot (RCT 2000va), about 2 weeks back.
Hoped to have it keep my little home server and RAID external alive, plus maybe the modem during loadshedding.
Plugged it in the 1st night and charged it. Next morning, power went out, and plugged in my modem and phone line - and apart from the constant beeping, worked a charm.
Disconnected all, and kept it plugged in.
Since then, we've hardly had loadshedding. The once or twice we were hit, I wasn't at home, so couldn't really check things.
This morning - it hit, and the UPS didn't kick in at all.
Disconnected everything.
Plugged it into mains, and realised that my old kettle-plug input, was very finnicky. A slight knock, and it shifts where it connects to the UPS input, and then doesn't charge.
I'm now thinking that the UPS has been uncharged for a while?
So when I plug a tiny radio into the back, with the Mains on>UPS>Radio, all works.
Switch off mains, and UPS + Radio dies....
Installed the software. This is what I see:
On the front of the unit, the AC Mode light is constant (as opposed to flashing, to indicate battery).
The top light, which indicates the AC Mode Load level is on low (which makes sense, since nothing is plugged in).
As soon as I kill the input switch, the unit dies.
Am I correct in surmising it simply isn't charging?
Is it faulty, or am I (more likely) missing something eye-wateringly face-palm-required obvious?
