Hi all.
It's been a long time since somebody just needed some technical advice on this forum. Lately is just negativity and moaning (understandably so).
I am in need of some technical advice.
I host files on my machine at home, using MyWireless, but when I download them all binaries goes corrupt. Text files are fine. My setup is a Broadband (Gigabyte BR404) Router, that connects via PPPoE with my sentech paperweight. The router has 4 Lan ports to which the server in question is linked to. The machine is set up as the DMZ. When i access my Dynamic IP over the net, you basically see my machine and not the router.
Files hosted with IIS as well as numurous other FTP packages goes corrupt when downloaded from my office connection (DSL).
Files I download from home (MyWireless) over the net are fine, just hosting them is a problem.
Any ideas?
Thanks in advance everybody.[
<font color="purple"><font size="1">Helderkruin,45%Signal Strength, Seeing light at the end of the tunnel!</font id="size1"></font id="purple">
Any ideas?
