cybershark
- Apr 11, 2006
I've got 2 adsl accounts so I put it into bridge mode using http://192.168.0.1/setup.cgi?next_file=mode.htm
Then as I disconnected from one of the isp's, I mistakenly clicked on the Lan one and disconnected from it
So just as a modem it works fine but now I have a problem, I can't login to the router at all. Which is what I will do on the 1st. Is there any way to solve this apart from resetting to factory default settings.
When I try I get:
I had to manually assign the LAN IP's below for my pc to even see the router
IP Address. . . . . . . . . . . . : 169.254.209.185
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . : 192.168.0.1
I've tried this IP as the Default Gateway 169.254.255.255
It was in my firewall log.
When I try I get:
Forbidden
You were denied access because:
Access denied by access control list.
