Slootvreter
- Aug 7, 2008
Yesterday I checked my car's fluid levels and then I noticed that my oil filler cap is a little loose. It does not leak oil. SHould this cap be airtight? Volvo S40 2.4i
Yes it should be snug. If you remove it while the engine is running, the idle will become uneven.
Check the sealing ring underneath. It may just be worn. They usually come with rebuild kits. The dealer may just have an extra one lying around and give it you for free or a nominal cost.
You need an new L10 cap.![]()
What vehicle is it?
Probably good to take into consideration that you get different types of caps with different seals?
Some is the conventional screw on type that seals tightly, others you have to push down before turning (similar to the child proof type bottle caps) and they have some play.
My old car - screw on and was tight
New one - some play in both the oil and fuel cap.
