Oil Stain on Driveway
W.Salie
Hi
I have an old oil stain in my driveway that I would like to remove and Im not sure what I can use to remove it. I tried scrubbing it with various household cleaning agents but to no avail the stain is still there, any ideas? someone told me pool acid work and I am yet to try it... any other ideas?
AstroTurf
Lucky Shot
Buy some trisodium phosphate from http://cim.co.za/
Buy some kitty litter (enough to cover the oil stain).
Buy a plastic sheet big enough to cover the oil stain.
Make some mud out of the trisodium phosphate and kitty litter.
Cover the stain with it.
Cover that with the sheet.
Leave for 24 hours.
Collect the kitty litter for future use.
Wash the driveway.
Zyraz
Hi
Hi pressure washers should also be able to help .
Stokstert
Prepsol engine cleaner from motoring outlets like Midas. Brush with Prepsol and hose off after soaking for a while.
saturnz
have your drive way sealed thereafter, oil stains will come out in the rain with no effort required
deweyzeph
All these suggestions are completely moot unless the OP can tell us what his driveway is made of.
StrontiumDog
Maybe he owns a oil stain removal company and is just waiting till there are enough subscribers to this thread before he presents us with an amazing solution ... :whistling:
