Opel corsa Lite 2005 fuel economy
ArmatageShanks
Howsit guys, I have a 2005 Opel Corsa Lite with 68000km on the clock I just did a service: plugs, air filter, oil filter, oil and radiator flush, before the service I got 11.9 km per liter and after I got 12.7. Now I have no idea of weather this is good for the car or not but will it be worth while taking the car to bosh for diagnostics just to make sure everything is in timing and that no errors pop up?
dj_jyno
I don't see a problem - your fuel economy has improved following the service.
supersunbird
You are getting more KM per litre, so that sounds good.
Or else you made a mistake in your post?
dillinger
Sounds right, my GF gets 15km to the litre with hers, has 140K on the clock.
KingMikel
My Corsa was also heavy on juice. 10km/l.
Apparently the temp sensor goes on these and that impacts your fuel economy. Maybe try replace that?
Otherwise there are random things you can try that'll probably have little effect - Reset ECU, replace fuel filter.
But, I really do think you're stuck with that fuel economy! The Corsas perform well, they're just not fuel efficient.
Rouxenator
Dank meme lord
Sadly the Corsa B (Lite) and C (Gamma) has some of the thirstiest petrol engines around.
