Hello all just updated my opera to version 9. Now www.vodacom4me.co.za has gone all strange. It seems to think my laptop is a phone ? checked I.E is fine
Yep, I think that's the problem, when I set opera to identify itself as IE or Mozilla, the site renders correctly.vodacom3g said:Don't the browsers present some kind of ID so the servers know how to format?
Probably 4me now does not recognise the browser?
Same happens in the previous version (8.5) when set to identify as Opera, but in that version, it was set to identify as IE by default, and that's probably why it worked previously.ic said:Then Opera should allow web to set the browser string in such a way that it identifies itself [to servers] as the previous version of Opera that rendered properly...?
Cell C 3G said:In opera go to Tool -> Quick Preferences -> Edit Site Preferences -> Network
Then at the bottom of the window you'll see Browers Identification. Choose 'Identify as Internet Explorer' Click ok.
Then all pages should display correctly.
*cough*firefox*cough*web said:opera 9 problems ?
jarr said:*cough*firefox*cough*![]()
hmm.. but hten why is it set to ID as Opera by default. I know the older versions were ID as IE by default. I thought it was changed for a reasn.Prometheus said:Ekhaatvensters: That is exactly what you should do, but the new Opera seems to work only on a per site basis. Type opera:config into the address bar, select "User Agent" and in the box that opens set it to 2 or 3 to fix it for good.Yep, just make shure you dont do this for the whole of Opera in general. this happens when you change that setting in preferences of the entire browser.
I dont think it'll make a difference whatsoever, because this is only the way it identifies itself to the webserver, AFIAK it doesn't change the way it renders a page.Ekhaatvensters said:Yu guys shure this is the right setting to leave it on for every page? Wont it be slower, even though maby a bit beter rendering for some pages? Id rather just change the pages that need to be changed.
Yep it was changed for a reason. Probably to be compatible with Opera. Confused? Let me explain it this way. It was always set to IE by default. It should actually be set to Opera. The identification string is always sent to javascripts when they request it and is most often used there and not by actual servers. You can check this by typing "<script type='text/javascript'>document.write(navigator.userAgent);</script>" into an empty page and loading it.hmm.. but hten why is it set to ID as Opera by default. I know the older versions were ID as IE by default. I thought it was changed for a reasn.
piranha786 said:What I dislike opera is when I use this forum, it don't give me a little detail of the post when I hover on the thread headings like IE does
do you ppl understand what I just said???
Understand what you mean, it works with me too.piranha786 said:What I dislike opera is when I use this forum, it don't give me a little detail of the post when I hover on the thread headings like IE does
Your forgiven. I thought there was an error with the new server. Quite alright since it was quoted anyway.ic said:@Prometheus, have sent you an apology via p.m. - accidentally zapped your post - was very tired at the time.
Another extention for Firefox? In Opera you can just disable it in your general preferences and enable it on a per site basis. Can even control gif animation and background sounds this way.For ages, I have had the NoScript extension installed in my Firefox, which allows me to control which websites are allowed to use ECMAScript - only the sites I trust 100% to not have malicious javascript are permanently enabled to allow javascript, by default an untrusted website isn't allowed to use javascript in my Firefox,
does this help?piranha786 said:What I dislike opera is when I use this forum, it don't give me a little detail of the post when I hover on the thread headings like IE does
That's fixed in Opera 9 afaik.jarr said:does this help?
