Pinetown (Highway Area - Durban) ADSL Problems
SirFooK'nG
As per RPM's request. Details for my area (this being my work ADSL).
Issue: Exchange is 10mb enabled. I cant get a stable connection at anything higher than 4mb, tried 8 & 6 but was useless...
Area Code: 031 701 (http://www.broadbandstats.co.za/exchange/NPWN)
ADSL Line Speed: Currently set for 4mb
ISP: MWEB or Afrihost (use both)
Time of issues: Permanent if trying to sync at a higher speed than 4mb
Trace Route:
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>tracert www.telkom.co.za
Tracing route to www.telkom.co.za [165.143.158.8]
over a maximum of 30 hops:
1 2 ms 1 ms 2 ms 192.168.1.1
2 8 ms 8 ms 8 ms 41-132-60-1.dsl.mweb.co.za [41.132.60.1]
3 37 ms 9 ms 10 ms 197-82-5-250.dbn.mweb.co.za [197.82.5.250]
4 10 ms 9 ms 9 ms 197-82-2-3.dbn.mweb.co.za [197.82.2.3]
5 20 ms 20 ms 20 ms tengig0-0-0.vic-pr-1.mweb.co.za [197.80.4.141]
6 62 ms 68 ms 108 ms jhb.telkom-ipnet.co.za [197.80.4.117]
7 21 ms 20 ms 21 ms 196.43.25.137
8 22 ms 22 ms 23 ms 196.43.51.78
9 * * * Request timed out.
10 * * telkom-sa-tienet-gw.telkom-ipnet.co.za [196.25.54.62] reports: Destination n
et unreachable.
Trace complete.
ADSL LinkDownstreamUpstream
Connection Speed4088 Kbps511 Kbps
Line Attenuation38.1 dB22.0 dB
Noise Margin11.7 d11.8 dB
[tr]
wvermaak86
==== Cowies Hill, Pinetown, Durban ====
This is for my home network in Cowies Hill, Pinetown.
Issue: Exchange is 10mb enabled. I cant get a stable connection at anything higher than 1mb, for more than 2 years! :mad:
Area Code: 031 701 xxxx (http://www.broadbandstats.co.za/exchange/NPWN)
ADSL Line Speed: Currently set for 4mb - but only achieving 1mb :mad:
ISP: Afrihost - 4mb 60GB Capped (Don't like the idea of being throttled)
Router: Netgear DGN2200M V2
Time of issues: Permanent if trying to sync at a higher speed than 1mb :mad:
Suggested solution: Add an exchange in the Cowies Hill area, we are way too far away from the current Pinetown Exchange. I also believe the Pinetown exchange is severely congested.
C:\Users\xxxxx>tracert telkom.co.za
Tracing route to telkom.co.za [196.43.22.222]
1 1 ms 1 ms <1 ms 10.0.0.2
2 10 ms 10 ms 10 ms 105-236-7-129-esr-lo.mtnbusiness.co.za [105.236.
7.129]
3 27 ms 26 ms 26 ms ipc-recieve-ng-1a.mtnbusiness.net [41.181.201.14
4 20 ms 21 ms 21 ms ng-mse-1--ng-cr-1-a.za.mtnns.net [196.44.27.68]
5 25 ms 28 ms 24 ms jh-cr-1.za--ng-cr-1.za.mtnns.net [196.44.31.176]
6 21 ms 21 ms 20 ms rb-cr-2.za--jh-cr-1.za.mtnns.net [196.44.0.43]
7 19 ms 19 ms 18 ms qux--rb-dca-2.za-b.za.mtnbusiness.net [41.181.16
5.119]
8 20 ms 21 ms 20 ms rrba-ip-se-2-wan.telkom-ipnet.co.za [196.25.58.1
7]
9 25 ms 24 ms 24 ms 196.43.25.137
10 22 ms 22 ms 21 ms 196.43.39.162
11 30 ms 30 ms 29 ms rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za [196.4
3.23.6]
12 30 ms 29 ms 29 ms nbsc-ip-bssr-2-atm-5-0-0-1.telkom-ipnet.co.za [1
96.43.23.34]
13 29 ms 29 ms 29 ms nbsc-ip-rcache-1-vif0.telkom-ipnet.co.za [196.43
.22.222]
Trace complete.
Connection Speed1408 kbps507 kbps
Line Attenuation46.5 db25.8 db
Noise Margin12.6 db12.6 db
Gox
== Cowies Hill == Pinetown
Issue: Exchange supposedly 10mb, if I phone they say max 4mb. I'm syncing on 4mb, but for the last 3 weeks it has been rapidly losing sync, resyncing at slower rate etc. Very unstable.
ISP: Mweb 4mb uncapped premium
Router: Billion N73x & DuoPlus 300WR
The Duoplus is the older backup router, but handles the line sync better
The billion constantly loses sync and resyncs at slower speed
I'm not super far from my exchange and line quality has always been ok.
I suspect there is some copper damage somewhere off my yard, because the Line attenuation and Noise margin jumps through the roof when there is a problem syncing. Nothing on my side wrong, I have decent tech skills, I've checked all the normal nonsense from unprotected wires, replacing splitters, no normal phones in house, no telkom monitored alarms etc. No branches catching the line etc.
Telkom number: 031 701 9***
Traceroute while connection synced at 4mbs: (will update when it screws up again)
traceroute telkom.co.za
traceroute to telkom.co.za (196.43.22.222), 64 hops max, 52 byte packets
1 login.router (10.0.0.2) 2.533 ms 5.743 ms 2.793 ms
2 41-133-72-1.dsl.mweb.co.za (41.133.72.1) 9.683 ms 10.109 ms 9.246 ms
3 197-82-5-250.dbn.mweb.co.za (197.82.5.250) 12.650 ms 11.361 ms 11.568 ms
4 197-82-2-3.dbn.mweb.co.za (197.82.2.3) 36.367 ms 10.926 ms 11.045 ms
5 jhb.telkom-ipnet.co.za (197.80.4.117) 21.670 ms 22.820 ms 22.423 ms
6 196.43.25.137 (196.43.25.137) 22.741 ms 22.057 ms 21.676 ms
7 196.43.39.162 (196.43.39.162) 21.580 ms 25.096 ms 23.064 ms
8 rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za (196.43.23.6) 22.725 ms 21.948 ms 22.968 ms
9 nbsc-ip-bssr-2-atm-5-0-0-1.telkom-ipnet.co.za (196.43.23.34) 23.951 ms 24.858 ms 24.577 ms
10 telkom.co.za (196.43.22.222) 24.352 ms 24.341 ms 27.151 ms
ADSL line information while synced at 4mbps (will update when its dc ing again)
Modem Status
Connection Status Connected
Us Rate (Kbps) 511
Ds Rate (Kbps) 4092
US Margin 19
DS Margin 17
Trained Modulation ADSL_2plus
LOS Errors 0
DS Line Attenuation 26
US Line Attenuation 13
Gox
Internet completely screwed since last night, Line is failing to sync at 1mb
Downstream margin has dropped to under 6, constant sync failures
Nothing plugged in onto my line, did electronic isolation tests in my house, unplugged everything electronic in the house, switched to new pots filter etc. still screwed
Giving me gray hairs:
Line stats today (compare to the ones in previous post)
login.router (10.0.0.2) 2.626 ms 1.638 ms 1.547 ms
2 41-133-72-1.dsl.mweb.co.za (41.133.72.1) 10.009 ms 10.697 ms 10.226 ms
3 197-82-5-250.dbn.mweb.co.za (197.82.5.250) 11.506 ms 11.774 ms 12.051 ms
4 197-82-2-3.dbn.mweb.co.za (197.82.2.3) 12.040 ms 12.906 ms 12.740 ms
5 jhb.telkom-ipnet.co.za (197.80.4.117) 22.988 ms 22.510 ms 23.115 ms
6 196.43.25.137 (196.43.25.137) 22.511 ms 25.943 ms 22.692 ms
7 196.43.39.166 (196.43.39.166) 22.975 ms 22.801 ms 23.528 ms
8 rrba-ip-bssr-1-ge-2-48.telkom-ipnet.co.za (196.43.23.6) 23.401 ms 23.626 ms 23.321 ms
9 nbsc-ip-bssr-1-atm-5-0-0-1.telkom-ipnet.co.za (196.43.23.30) 25.039 ms 25.266 ms 25.391 ms
10 telkom.co.za (196.43.22.222) 24.899 ms 25.462 ms 25.051 ms
Modem Status
Us Rate (Kbps) 387
Ds Rate (Kbps) 1297
US Margin 5
DS Margin 6
LOS Errors 0
DS Line Attenuation 41
US Line Attenuation 42
Peak Cell Rate 912 cells per sec
CRC Rx Fast 95
CRC Tx Fast 0
CRC Rx Interleaved 0
CRC Tx Interleaved 0
Path Mode Fast Path
And now its back to normal at 21h00
Modem Status
Us Rate (Kbps) 511
Ds Rate (Kbps) 4092
US Margin 15
DS Margin 12
LOS Errors 0
US Line Attenuation 12
