I don't think so. It's supposed to make up like 70 or 80% of the universe or something like that. So, I'm pretty sure it's all around, not just far away. Also, I thought it was supposed to be some undetectable / as yet unknown form of matter (hence the dark); so, NOT H or He then.
Ahhh, well, given that most of your gass planets are made of lighter gases like Helium and hydrogen, so that's a safe assumption. Furthermore, it's composition isn't really vital, and given then it's 4 times the size of Jupiter, if it were made of things too heavy, it would be a massive rock planet, not many things are in gaseous form.
It's also not visible because it's pretty far away, however, given it's size, there should be a massive ball shining infrared radiation, which would be pretty noticeable. Also, you'd see massive amounts of those icey-rocks buzzy around it due to it's one gravity well, unless it's got so much crap spinning around it that you can't see it
The only way they gonna find it is maybe to fly over there and take a look
The universe is still so mysterious. I can't wait for light speed travel.
Well, I don't think anything with mass can go to the speed of light, as the faster you go, your relative mass increases, and when you start playing with speeds at about 99% of the speed of light, you mass increases at a massive rate, meaning you need infinite energy so you gain infinite mass, which isn't feasible.
You mean the wormhole kind?
Those would be useful
, instead of stuffing around with going really fast and have relativity kick you in the ass, you just cut a hole in the fabric of space and time, and jump to another end of the universe
