# DO NOT EDIT THIS FILE
# It is automatically generated by /usr/sbin/grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s /boot/grub/grubenv ]; then
have_grubenv=true
load_env
fi
set default="0"
if [ ${prev_saved_entry} ]; then
saved_entry=${prev_saved_entry}
save_env saved_entry
prev_saved_entry=
save_env prev_saved_entry
fi
insmod ext2
set root=(hd2,2)
search --no-floppy --fs-uuid --set 220195fc-984f-48df-b3fe-44818d49ef5a
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=640x480
insmod gfxterm
insmod vbe
if terminal_output gfxterm ; then true ; else
# For backward compatibility with versions of terminal.mod that don't
# understand terminal_output
terminal gfxterm
fi
fi
if [ ${recordfail} = 1 ]; then
set timeout=-1
else
set timeout=10
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/white
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
menuentry "Ubuntu, Linux 2.6.31-19-generic" {
recordfail=1
if [ -n ${have_grubenv} ]; then save_env recordfail; fi
set quiet=1
insmod ext2
set root=(hd2,2)
linux /boot/vmlinuz-2.6.31-19-generic root=UUID=220195fc-984f-48df-b3fe-44818d49ef5a ro splash vga=789 quiet splash
initrd /boot/initrd.img-2.6.31-19-generic
menuentry "Ubuntu, Linux 2.6.31-19-generic (recovery mode)" {
recordfail=1
insmod ext2
set root=(hd2,2)
linux /boot/vmlinuz-2.6.31-19-generic root=UUID=220195fc-984f-48df-b3fe-44818d49ef5a ro single splash vga=789
menuentry "Ubuntu, Linux 2.6.31-14-generic" {
recordfail=1
set quiet=1
insmod ext2
set root=(hd2,2)
linux /boot/vmlinuz-2.6.31-14-generic root=UUID=220195fc-984f-48df-b3fe-44818d49ef5a ro splash vga=789 quiet splash
initrd /boot/initrd.img-2.6.31-14-generic
menuentry "Ubuntu, Linux 2.6.31-14-generic (recovery mode)" {
recordfail=1
insmod ext2
set root=(hd2,2)
linux /boot/vmlinuz-2.6.31-14-generic root=UUID=220195fc-984f-48df-b3fe-44818d49ef5a ro single splash vga=789
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry "Memory test (memtest86+)" {
linux16 /boot/memtest86+.bin
menuentry "Memory test (memtest86+, serial console 115200)" {
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry "Windows NT/2000/XP (loader) (on /dev/sdb1)" {
insmod ntfs
set root=(hd1,1)
search --no-floppy --fs-uuid --set 6a8c25528c251a59
drivemap -s (hd0) ${root}
chainloader +1
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
prefix=/usr
exec_prefix=${prefix}
libdir=${exec_prefix}/lib
. ${libdir}/grub/grub-mkconfig_lib
echo "Adding Windows" >&2
cat << EOF
menuentry "Windows XP2" {
EOF
save_default_entry | sed -e "s/^/\t/"
cat << EOF
insmod ntfs
set root=(hd1,1)
search --no-floppy --fs-uuid --set q67e48fd884ds522
chainloader +1
prefix=/usr
cat << EOF
menuentry "Windows XP3" {
EOF
cat << EOF
insmod ntfs
set root=(hd1,2)
chainloader +1
### END /etc/grub.d/40_custom ###
